Copiying reports
I have one report ( A )with two data providers
and
I have another report ( B) with three data providers
Now i want to copy B report into A report
I am in desktop intelligence using the single universe for both A and B report
Help me.
civilreddy (BOB member since 2007-05-04)
There is a utility in BOB’s Downloads that allows you to copy a data provider from one document to another. You might want to start there. That topic will include a link to the topic used to discuss that utility.
I did the same what you explained and it works fine for yesterday
But today i am getting error like
Error40:No rights, Cannot edit data provider
Pls help me to fix this issue
As I mentioned, each download topic has a link to a specific topic in an appropriate forum. That topic is intended to be the central location for all discussion related to that downloadable item, which makes it much easier for the original author to support it. :slight_smile:
Starting a new topic, or continuing in another (like this one) just makes it less likely that the author and/or those that are interested in supporting the utility will see your question.
For this particular item, that topic is here. Thanks.
