system
July 20, 2011, 5:06am
1
Hi BOBians,
I have a multi select prompt.
And have LOVs like…
1 - Delhi
20 - Jaipur
302 - Bangalore
33 - Hyderabad
987 - Pune
So, when I am displaying Prompt selection using UserResponse() in report. It displays like…
1 - Delhi;302 - Jaipur;33 - Hyderabad…
Is there any way using which I can convert this into… 1;302;33…
I just want to display numbers available in that string.
I tried to make my requirement clear, still if you need any more information, please update the thread.
TIA.
Rakesh_K (BOB member since 2007-12-11)
system
July 20, 2011, 6:51am
2
Use Pos function to find the position of “-” and then Substring or left function to fetch the required data.
You can try & let me know if it is not working , I will try to replicate the same at my end …
aniketp (BOB member since 2007-10-05)
system
July 20, 2011, 2:21pm
3
Suppose the object you have is Dim. Using the following code, you can show them in a table.
=Substr([Dim];1;Pos([Dim];"-")-1))
Lets work to show it in a cell.
M H Mohammed (BOB member since 2010-06-16)
system
July 25, 2011, 10:48am
4
Thanks Aniket,
It is a multi select prompt. So a user can select N number of values. How can i create a variable using POS() for such cases.
system
July 25, 2011, 4:55pm
5
Do you have separate object with just Id’s, if yes then you can bring it in the report and show it in horizontal table with out borders.
Zaif
zaif235 (BOB member since 2010-06-15)
system
July 25, 2011, 5:06pm
6
I think Cognos is wiser than BO on this. Try searching B B to find a topic where somebody has asked a Name field to be shown in a prompt where as internally it should use the ID field.
Jansi (BOB member since 2008-05-12)
system
July 26, 2011, 7:23am
7
Hi Rakesh, did you try the forula , what error or message you are getting?
system
July 26, 2011, 11:15am
8
@Aniket ,
how i can create a formula. Because sometimes user can select 1 value and some times more than 1.
Value of the UserResponse() will vary.
for example:
1 - Hyderabad;2-Bangalore
or
3 - Jaipur;5 - Pune;6 - Delhi
Can you please try on your end.
@Jansi ,
Please go through the post again, I am not looking for Index Awareness.
Let me explain this issue again.
I have two columns in database. location id and cityname.
Then I created a object called City = location id || ’ - ’ || cityname
Now I am using this object for my LOV.
So my LOV looks like…
1 - Hyderabad
2 - Delhi
3 - Jaipur
4 - Pune
and so on…
This prompt is a MULTI select prompt. So in UserResponse() i am getting string like “1 - Hyderabad;2 - Delhi;…”
I want to display this as “1;2…”
Just want to display locationids in a single cell.
system
July 26, 2011, 11:21am
9
Rakesh, if you simply take the Location Id to display won’t you get desired results.
Suppose you are selecting 4 values in your concatenated object and only those 4 location ids will appear in location id column, now if you display only location id object, you should able to achieve what you are looking for.
Now if you need that the output should be in order like 1;2;3;4 , then refer the below post-
I have two coumns with values, I need to get the columns 2 values separated by commas in the same line, is that possible in BO ?
Currently I have the ActionType values in mutiple lines of single Claim(WindowsDesc)
(Current:)
WindowsDesc ActionType
Claim1 AD
IQ
Claim2 AD
IQ
Claim3 IQ
NV
I am looking for the format: (expected)
Claim1 AD, IQ
Claim2 AD, IQ
Claim3 IQ, NV
system
July 27, 2011, 1:31am
10
Do a replace of Upper of userresponse()
Formula Would be something like below
=replace(replace(upper(userresponse());“A”;"");“B”;"")
Keep writing the replace for all the alphabets.
Hope it works for you.
prabhu_pramod (BOB member since 2010-06-17)
system
July 27, 2011, 6:03am
11
Thanks Aniket for sharing informative link, but this is not a clean solution in this case. As I am not displaying id column separately in report.
@Prabhu
What about special characters.
system
July 27, 2011, 3:44pm
12
U can do a replace for any character you want. Once you replace all the characters you dont need , your results will be what you want.
system
July 28, 2011, 6:03am
13
@prabhu
If i ll includes all the characters from all the languages then the formula will become pages long.
Is this you are suggesting?
system
July 29, 2011, 1:25am
14
There is no easy solution. But you can build a lot of little variables and then join them together.
This will get the first value
var1 =Substr([Dim];1;Pos([Dim];"-")-1))
and then you can build more variables to get others
var2 =Substr([Dim];length(Var1 );Pos([Dim];"-")-1))
var3 =Substr([Dim];length(Var2 );Pos([Dim];"-")-1))
etc etc
The you can …
FinalVar = var1+var2+var3
Problem is that you will have to guess how many variables to build.
weaver (BOB member since 2008-10-17)
system
July 29, 2011, 5:07am
15
There are around 7000 values in the list.
system
August 1, 2011, 11:38pm
16
But no one will choose 7000 items via the prompt. You can guess a maximum of 20 and make 20 variables.
Furthermore a prompt of 7000 items is hardly user friendly to begin with.
system
August 3, 2011, 5:23am
17
By assuming 20 selection from list will be a limitation.
Prompt is user friendly.
Some business users are familiar with id and some are interested in names. Also they can make use of search option to filter out values from LOV.
I want to pass only id to drill report as passing complete cityname will increase the URL length.
Also there is a limitation of 2083 characters for URL.
system
August 4, 2011, 1:44am
18
If all you are doing is wanting to pass the values then perhaps a second data provider?
Have your normal query with its prompts.
In your second data provider you just have
Select ID
FROM MyTable
WHERE ID IN MyPrompt
You can then display the returned rows in a Horizontal table formatted to look like a single cell.
system
August 4, 2011, 4:36am
19
I tried that.
I am able to display all ids into single cell.
like 1;2;3…
But I am not able to pass this into my drilldown report.
system
August 8, 2011, 3:48am
20
Try creating an object at the Universe level?
I use that technique to make rows of comments into one single comment.
This is an example from a SQL site
SELECT CustomerID, (SELECT OrderID AS ‘data()’ FROM Order O WHERE O.CustomerID = C.Customer ID FOR XML PATH(’’)) AS OrderList FROM Customer C
