I have a cross-tab report that calculates the total time in seconds for each task that a user has performed. So if user A has performed task X twice it will sum the two together. Ive used Datediff to calculate the duration in seconds and then the cross-tab calculates the sum.
However, I want to display the total time in hh:mm:ss in the cross-tab report. How do I do it?
Help much appreciated.
StephenPT (BOB member since 2012-08-02)
