Converting Embedded DF to Normal DF
Just Curious,
Is it possible to convert Embedded Data Flow into Normal Data Flow in easy steps, without doing much re-work!
data_guy :us: (BOB member since 2006-08-19)
I don’t think the tool supports this - you could of course export the EDF to atl and then edit the atl… although I am sure this would not be supported by SAP :wink:
speed12 (BOB member since 2004-09-27)
Not possible but in 3.2 the is copy/paste functionality. After ten years, aren’t we quick sometimes?
No kiddin’, it works very well, used it last week to merge a DF+EDF into one large DF.
