I have a situation where in a numeric column needs to be represented in HH:MM format. The value in the numeric column comes out as minutes
Example : If the value of the column is 300. We need to treat 300 as minutes .
300 needs to be represented as 05 : 00 format. Similarly
330 needs to be represented as 330 /60 = 5.5 which will be 05 : 30
380 needs to be represented as 380 /60 = 6.33 which should be 06 :20
I cannot convert the numeric field to datetime …but need to get the solution based on this information.
I have triied implementing the if logic in the webi
This throws me invalid data type error. I figured this out …as I am implemeting srting operation on a numeric data type…
I would request if I can be guided about any alternate method to achieve this.
I tried implementing it with using the said functions and format …but it throws me Invalid Input error just before the pound sign “#####”
Below is the code that I am using :
=If(Right(FormatNumber([Difference From Actual In And Login Minutes];"###") ;2)< 60;(Floor(ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];"###");2))/60))
“:” + ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];"###");2));(Floor(ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];"###");2))/60))
" : " + (ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];"###");2))-60))
Is it because of the version of the webi that I am using…though does not seems so…I am on BOE XI release 2. Please let me know.
[quote]=If(Right(FormatNumber([Difference From Actual In And Login Minutes];“###”) ;2)< “60”;(Floor(ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];“###”);2))/60))
“:” + ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];“###”);2));(Floor(ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];“###”);2))/60))
" : " + (ToNumber(Right(FormatNumber([Difference From Actual In And Login Minutes];“###”);2))-60))[quote]
