Convert Varchar to Decimal with scientific notation
I have a VARCHAR column that contains numbers that I need to convert to a DECIMAL(38,12)
Most of the numbers are regular decimals eg 334.98, 878.11332, etc
However, some of the numbers are in the column in scientific notation eg 2.8873322531580925E-2
The TO_DECIMAL_EXT function works perfectly for the normally formatted numbers, but errors on the numbers that contains scientific notation.
Any ideas as to how to get around this as right now I am stumped.
bungy :us: (BOB member since 2007-10-04)
it would be good if the varchar column avoids using scientific notation but I guess this is out of your control? If at all possible I would look to fix this β€˜root cause’ i.e. if it came from a csv from Excel then change number format in Excel.
One option to look at would be to push the conversion down to the database for example oracle’s to_number.
However I guess you can also apply a workaround by manually converting these numbers. Given that 3E-02 just means 3 x 10 to power of -2 = 0.03 then we can use,
if the value contains an E then take the numbers to the left of the E and multiply this by 10 to the power of the numbers to the right of the E.
So for your example 2.8873322531580925E-2 you would calculate 2.8873322531580925 * (10 to the power of -2)
use index function to locate position of E and then substring to get the two numeric values. probably want to put this together in a custom function.
AL
agulland :uk: (BOB member since 2004-03-17)
Thanks for the response.
I have come up with this handy function if any-one else needs it:
if (index($VarcharNumber,β€˜E’,1) IS NULL)
begin
Return to_decimal_ext($VarcharNumber,’.’,’,’,38,12);
end
else
begin
Return to_decimal_ext(word_ext($VarcharNumber,1,β€˜E’),’.’,’,’,38,24) * power(10, to_decimal_ext(word_ext($VarcharNumber,2,β€˜E’),’.’,’,’,38,12));
end
Here’s the inner workings of a custom function that handles +ve and -ve exponents:
$V_FORMATTED_NUMBER = $P_INPUT_STRING ;
Process positive exponents 1
if (lower($P_INPUT_STRING) like β€˜%e+%’)
begin
$V_POSITION = index(lower($P_INPUT_STRING) ,β€˜e’, 1);
$V_VALUE = substr($P_INPUT_STRING ,1, $V_POSITION -1);
$V_EXPONENT = ltrim( substr( $P_INPUT_STRING , $V_POSITION +2, 99),β€˜0’);
$V_FORMATTED_NUMBER = $V_VALUE * power( 10, $V_EXPONENT );
end
if (lower($P_INPUT_STRING) like β€˜%e%’ and lower($P_INPUT_STRING) not like β€˜%e+%’ and lower($P_INPUT_STRING) not like β€˜%e-%’)
begin
$V_EXPONENT = ltrim( substr( $P_INPUT_STRING , $V_POSITION +1, 99),β€˜0’);
end
Process negative exponents
if (lower($P_INPUT_STRING) like β€˜%e-%’)
begin
$V_FORMATTED_NUMBER = $V_VALUE * power( 10, $V_EXPONENT*-1 );
end
if (is_valid_double( $V_FORMATTED_NUMBER , β€˜##########.##########’) = 0)
$V_FORMATTED_NUMBER = β€˜β€™;
return $V_FORMATTED_NUMBER ;
Barry_Carlino (BOB member since 2010-12-16)
