Convert Seconds to Days, hours and minutes
Hello Friends,
I have a requirement where they want seconds to be converted to days, hours, minutes
Ex: 11924 seconds = 0 Days, 3 hours, 31 Minutes
I’m working on WEBI XI R2
Appreciate your help.
GJR
gjr (BOB member since 2005-06-09)
Do a search for “convert seconds”; there’s a bunch of existing topics.
I think you can edit this variable … or create new variable like
seconds/60 = which will display minutes
(seconds/60)/60= will display hours
((seconds/60)/60)/24= will display hours etc.,
Again you need to be careful…in some areas seconds will display in milli seconds…i.e., 1000 milliseconds is 1 sec…
Thanks & Regards,
Suresh Gooty
surya.g :india: (BOB member since 2009-11-24)
GJR,
This post can give you an idea:
[quote:55da03be75=“suresh.gooty”]I think you can edit this variable … or create new variable like
[/quote]
I guess this won’t give the desired result.
You need to use MOD() function also.
