Convert seconds into HH:MM:SS format
Dear BOB,
I have a column in the database which is having seconds.
Please assist to convert seconds into HH:MM:SS format
HUJ (BOB member since 2010-03-29)
Give the seconds as parameter it will give you in the format u want.
You can create an object in universe with definition
INTERVAL '8900' SECOND
Sample SQL:
select INTERVAL '8900' SECOND from dual
billu :india: (BOB member since 2009-11-09)
knra86,
Here is an older topic where a formula for DeskI is mentioned:
It should not be a problem to re-write the formula for WebI.
