Hi Mak1,
The following done in Netezza 7 (Twin-Fin) - need to have the Lua plugin and do the build in a derived table within the universe. In somecases it’s more feasable to employ this sort of approach, rather than replicate some huge table via ETL - the example below is done on say 40+ million transactions per day.
SELECT DISTINCT SEQ, CALL_ID, DATE_TM, MEASUREMENT_DATA_ID, ECNO, RCSP, CELL_ID
FROM RNC.ETL.MEASUREMENT_DATA as a
INNER JOIN RNC.ETL.MESSAGE_DATA AS b ON b.MESSAGEDATAID = a.MEASUREMENTDATAID
cross join table(inza..nzlua('
local rows={}
function processRow(CALLID, TIMESTAMP,MEASUREMENTDATAID , ECNO1 , ECNO2, ECNO3 ,ECNO4
, EVALUATEDECNO1 ,EVALUATEDECNO2, EVALUATEDECNO3
, RSCP1, RSCP2, RSCP3, RSCP4, EVALUATEDRSCP1, EVALUATEDRSCP2, EVALUATEDRSCP3
, CELLID1, CELLID2, CELLID3, CELLID4, EVALUATEDCELLID1, EVALUATEDCELLID2
, EVALUATEDCELLID3)
rows[1] = {1, CALLID, TIMESTAMP, MEASUREMENTDATAID, ECNO1, RCSP1, CELLID1}
rows[2] = {2, CALLID, TIMESTAMP, MEASUREMENTDATAID, ECNO2, RCSP2, CELLID2}
rows[3] = {3, CALLID, TIMESTAMP, MEASUREMENTDATAID, ECNO3, RCSP3, CELLID3}
rows[4] = {4, CALLID, TIMESTAMP, MEASUREMENTDATAID, ECNO4, RCSP4, CELLID4}
rows[5] = {5, CALLID, TIMESTAMP, MEASUREMENTDATAID, EVALUATEDECNO1, EVALUATEDRSCP1, EVALUATEDCELLID1}
rows[6] = {6, CALLID, TIMESTAMP, MEASUREMENTDATAID, EVALUATEDECNO2, EVALUATEDRSCP2, EVALUATEDCELLID2}
rows[7] = {7, CALLID, TIMESTAMP, MEASUREMENTDATAID, EVALUATEDECNO3, EVALUATEDRSCP3, EVALUATEDCELLID3}
return rows
end
function getShape()
columns={}
columns[1] = { "SEQ", integer }
columns[2] = { "CAll_ID", bigint }
columns[3] = { "DATE_TM", datetime}
columns[4] = { "MEASUREMENT_DATA_ID", bigint }
columns[5] = { "ECNO", integer }
columns[6] = { "RCSP", integer }
columns[7] = { "CELL_ID", bigint }
return columns
end',
b.CALLID, b.TIMESTAMP, a.MEASUREMENTDATAID , a.ECNO1 , a.ECNO2, a.ECNO3 ,a.ECNO4
, a.EVALUATEDECNO1 ,a.EVALUATEDECNO2, a.EVALUATEDECNO3
, a.RSCP1, a.RSCP2, a.RSCP3, a.RSCP4, a.EVALUATEDRSCP1, a.EVALUATEDRSCP2, a.EVALUATEDRSCP3
, b.CELLID1, b.CELLID2, b.CELLID3, b.CELLID4, a.EVALUATEDCELLID1, a.EVALUATEDCELLID2
, a.EVALUATEDCELLID3 ))
WHERE b.CALLID = @Prompt( 'ID' , 'N', , mono, free, persistent )
And also the (little known of) REGEX function I mentioned, also done within Netezza:
SELECT
src.SRC_FILE_NM,
src.GGSN_PGW_CDR_KEY,
src.REC_TYPE,
src.NTWK_INIT,
src.SRVD_IMSI,
src.GGSN_ADDR1,
src.GGSN_ADDR2,
src.GGSN_ADDR3,
src.GGSN_ADDR4,
src.CHRGNG_ID,
src.SGSN_ADDR1,
src.SGSN_ADDR2,
src.SGSN_ADDR3,
src.SGSN_ADDR4,
src.ACCESS_POINT_NM,
src.PDP_TYPE,
src.SRVD_PDP_ADDR1,
src.SRVD_PDP_ADDR2,
src.SRVD_PDP_ADDR3,
src.SRVD_PDP_ADDR4,
src.DYNAMIC_ADDR_FLAG,
src.DATA_VOL_UP,
src.DATA_VOL_DOWN,
src.REC_OPEN_TIME,
src.TOT_DURATION_ALL_RTNG_GRPS,
src.REAS_FOR_CLOSURE,
src.DIAGNOSTICS,
src.REC_SEQ_NUM,
src.NODE_ID,
src.LOCAL_SEQ_NUM,
src.SRVD_MSISDN,
src.CHRGNG_CHARACTERISTICS,
src.SGSN_PLMN_IDENTIFIER,
src.SRVD_PDP_PDN_ADDR5,
src.DIAGNOSTICS_GSM_ERR_VAL,
src.DIAGNOSTICS_ITU_CAUSE,
src.DIAGNOSTICS_ID,
src.DIAGNOSTICS_SIG,
src.DIAGNOSTICS_INFO,
src.DIAGNOSTOCS_MANUFACTURER_SPECIFIC_CAUSE,
src.DIAGNOSTICS_POS_MTHD_FAILR_CAUSE,
src.DIAGNOSTICS_UNATHRZD_CS_CLIENT_CAUSE,
src.APN_SELCTN_MODE,
src.CHCH_SELCTN_MODE,
src.SRVD_IMEI,
src.RAT_TYPE,
src.MS_TM_ZN,
src.USR_LOC_INFO,
DECODE(c1.str,'',Null,c1.str) LST_SVC_DATA_RTNG_GRP,
c2.str CHRGN_RULE_BASE_NM,
DECODE(c3.str,'',Null,c3.str) RESULT_CD,
DECODE(c4.str,'',Null,c4.str) LST_SVC_DATA_LOC_SEQ_NUM,
--CAST(c5.str as TIMESTAMP) DTTM_FRST_USG,
TO_DATE(c5.str,'YYYYMMDDHH24MISS') DTTM_FRST_USG,
TO_TIMESTAMP(c6.str,'YYYYMMDDHH24MISS') DTTM_LAST_USG,
DECODE(c7.str,'',Null,c7.str) TM_USG,
c8.str SVC_COND_CHNG,
DECODE(c9.str,'',Null,c9.str) LST_SVC_DATA_QCI,
DECODE(c10.str,'',Null,c10.str) LST_SVC_DATA_MAX_REQSTD_BNDWDTH_UL,
DECODE(c11.str,'',Null,c11.str) LST_SVC_DATA_MAX_REQSTD_BNDWDTH_DL,
DECODE(c12.str,'',Null,c12.str) LST_SVC_DATA_GUARTD_BITRATE_UL,
DECODE(c13.str,'',Null,c13.str) LST_SVC_DATA_GUARTD_BITRATE_DL,
DECODE(c14.str,'',Null,c14.str) LST_SVC_DATA_ARP,
DECODE(c15.str,'',Null,c15.str) LST_SVC_DATA_APN_AGGR_MAX_BITRATE_UL,
DECODE(c16.str,'',Null,c16.str) LST_SVC_DATA_APN_AGGR_MAX_BITRATE_DL,
c17.str LST_SVC_DATA_ADDR1,
c18.str LST_SVC_DATA_ADDR2,
c19.str LST_SVC_DATA_SGSN_PLMN_IDENTIFIER,
DECODE(c20.str,'',Null,c20.str) DATA_VOL_FBC_UP,
DECODE(c21.str,'',Null,c21.str) DATA_VOL_FBC_DOWN,
TO_DATE(c22.str,'YYYYMMDDHH24MISS') REPORT_DTTM,
DECODE(c23.str,'',Null,c23.str) LST_SVC_DATA_RAT_TYPE,
DECODE(c24.str,'',Null,c24.str) LST_SVC_DATA_FAILR_HNDLNG_CNTNU,
DECODE(c25.str,'',Null,c25.str) LST_SVC_DATA_SVC_ID,
c26.str LST_SVC_DATA_USR_LOC_INFO,
c27.str NUM_EVNTS,
c28.str EVNT_DTTM_TMSTMPS,
DECODE(c29.str,'',Null,c29.str) TM_QUOTA_TYPE,
DECODE(c30.str,'',Null,c30.str) BASE_TM_INTRVL,
src.NODE_ADDR1,
src.SUBS_ID_TYPE,
src.SUBS_ID_DATA,
src.PGW_PLMN_ID,
TO_DATE(src.START_DTTM,'YYYYMMDDHH24MISS') START_DTTM,
TO_DATE(src.STOP_DTTM,'YYYYMMDDHH24MISS') STOP_DTTM,
src.SRVD_3GPP2ME_ID,
src.PDN_CONN_CHRGNG_ID,
src.IMSI_UNAUTHNTCTD_FLG,
src.CSG_ID,
src.CSG_ACCESS_MODE,
src.CSG_MEMBRSHP_IND,
src.THREEGPP_2USR_LOC_INFO,
src.SRVD_PDP_PDN_ADDR_EXT1,
src.SRVD_PDP_PDN_ADDR_EXT2,
src.DYNAMIC_ADDR_FLAG_EXT,
c1.POS CDR_SEQ_NUM
FROM
STAGE..STAGE_GGSN_PGW_CDRS src
CROSS JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_RTNG_GRP,',,,,,,,,,'),',')) split_pivot_col
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_RTNG_GRP,',,,,,,,,,'),',')) c1 on split_pivot_col.POS = c1.POS AND c1.str not in ('')
INNER JOIN TABLE (regexp_split_rows(nvl(src.CHRGN_RULE_BASE_NM,',,,,,,,,,'),',')) c2 on split_pivot_col.POS = c2.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.RESULT_CD,',,,,,,,,,'),',')) c3 on split_pivot_col.POS = c3.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_LOC_SEQ_NUM,',,,,,,,,,'),',')) c4 on split_pivot_col.POS = c4.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.DTTM_FRST_USG,',,,,,,,,,'),',')) c5 on split_pivot_col.POS = c5.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.DTTM_LAST_USG,',,,,,,,,,'),',')) c6 on split_pivot_col.POS = c6.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.TM_USG,',,,,,,,,,'),',')) c7 on split_pivot_col.POS = c7.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.SVC_COND_CHNG,',,,,,,,,,'),',')) c8 on split_pivot_col.POS = c8.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_QCI,',,,,,,,,,'),',')) c9 on split_pivot_col.POS = c9.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_MAX_REQSTD_BNDWDTH_UL,',,,,,,,,,'),',')) c10 on split_pivot_col.POS = c10.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_MAX_REQSTD_BNDWDTH_DL,',,,,,,,,,'),',')) c11 on split_pivot_col.POS = c11.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_GUARTD_BITRATE_UL,',,,,,,,,,'),',')) c12 on split_pivot_col.POS = c12.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_GUARTD_BITRATE_DL,',,,,,,,,,'),',')) c13 on split_pivot_col.POS = c13.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_ARP,',,,,,,,,,'),',')) c14 on split_pivot_col.POS = c14.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_APN_AGGR_MAX_BITRATE_UL,',,,,,,,,,'),',')) c15 on split_pivot_col.POS = c15.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_APN_AGGR_MAX_BITRATE_DL,',,,,,,,,,'),',')) c16 on split_pivot_col.POS = c16.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_ADDR1,',,,,,,,,,'),',')) c17 on split_pivot_col.POS = c17.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_ADDR2,',,,,,,,,,'),',')) c18 on split_pivot_col.POS = c18.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_SGSN_PLMN_IDENTIFIER,',,,,,,,,,'),',')) c19 on split_pivot_col.POS = c19.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.DATA_VOL_FBC_UP,',,,,,,,,,'),',')) c20 on split_pivot_col.POS = c20.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.DATA_VOL_FBC_DOWN,',,,,,,,,,'),',')) c21 on split_pivot_col.POS = c21.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.REPORT_DTTM,',,,,,,,,,'),',')) c22 on split_pivot_col.POS = c22.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_RAT_TYPE,',,,,,,,,,'),',')) c23 on split_pivot_col.POS = c23.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_FAILR_HNDLNG_CNTNU,',,,,,,,,,'),',')) c24 on split_pivot_col.POS = c24.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_SVC_ID,',,,,,,,,,'),',')) c25 on split_pivot_col.POS = c25.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.LST_SVC_DATA_USR_LOC_INFO,',,,,,,,,,'),',')) c26 on split_pivot_col.POS = c26.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.NUM_EVNTS,',,,,,,,,,'),',')) c27 on split_pivot_col.POS = c27.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.EVNT_DTTM_TMSTMPS,',,,,,,,,,'),',')) c28 on split_pivot_col.POS = c28.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.TM_QUOTA_TYPE,',,,,,,,,,'),',')) c29 on split_pivot_col.POS = c29.POS
INNER JOIN TABLE (regexp_split_rows(nvl(src.BASE_TM_INTRVL,',,,,,,,,,'),',')) c30 on split_pivot_col.POS = c30.POS;
Mak1 - I see you have some NZSQL experience, so im sure the above would be of use!! Hove you got any experience with ESRI Geospatial plugin?
Thomas
Thomas Evans
(BOB member since 2013-10-17)
