Conversion from deski to webi
Hello,
I try to convert a report from deski to webi.
It is partially done and when looking to the results i have a very strange behaviour.
A fact is the gross turnocer.
In deski it is ok
in webi the amount is doubled as if the migration has brought a kind of Fan trap that would be naturally solved in Deski.
Did you get such behaviour ?
Thank you
Jérôme
grodeg (BOB member since 2013-02-22)
Is the SQL the same?
jemstar :ireland: (BOB member since 2006-03-30)
Hello,
Yes exactly the same SQL is generated on the two reports.
In Deski i can see that the way a report is built is quite different from webi, if i look to the migrated reprot from the web rich client, I can see a lot of cells that dont appear in the deski one.
