Conversion error unknown reason
Hi all,
I’m getting some strange errors when using the report conversion tool. It used to work fine but at the moment I’m getting errors about the detail variable not being linked to a dimension - and this is failing the conversion completely, not even partially converting.
The current error on the report I’ve got a problem with says “The wid file could not be generated due to an unknown reason”. Any ideas where I go from here?
Btw, am on XIR2 SP4 FP4.7
malteser (BOB member since 2006-02-21)
All the universe object are intact and properly linked…You canc heck Report Conversion gudie and check what are limitations and what the status mean while doing conversion
http://help.sap.com/businessobject/product_guides/boexir31/en/xi3-1_report_conversion_tool_guide_en.pdf
Nirav
nniravv :india: (BOB member since 2007-08-16)
