I’m working on Data Services with BW as target.
I’ve followed the steps given in the url below :
http://wiki.sdn.sap.com/wiki/display/BOBJ/Loading+BW
I was able to run the jobs from BW & pull data via DS when DS jobserver was on windows. Now the DS jobserver is on Solaris 10, DS 3.2 (repo version is 12.2.0.0) & the job fails to get executed.
I’m able to run RfcSvr… command from command prompt of solaris & can read data from BW (SAP BW as Source); but when it comes for writing data into BW (SAPBW as Target) I was getting an error “Java Connector (JCo) not found”. I got the file downloaded & installed it in the specified folder but then also the same error continued moreover RfcSvr command stopped responding. Hence I reverted back to the originial state.
I’m able to generate the *.sh file from export exectuion command & can run the job from BW when the target is an database table. But when the target is BW objects the job fails; no log is found in the log file.
Can anyone help me to get out of this asap. I’m trying all possible methods since 2 weeks.
Thanks in advance.
Arun
hsarun28 (BOB member since 2009-12-07)
