connection sql
I created the ODBC on the server.
And I created the connection on the Designer, but when I tried to test, I had that error:
the server is not responding …
DBD: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified.
Could you help me please?
Renata
santana (BOB member since 2009-04-16)
check user_name, password and database are correct
or
connect to the database using the user/pass… using SQL utility., then use the same user/pass and database in your connection.
With the above, you can find out whether the server is up and running and accepting connections.
Did you try testing the connection in Designer in your local desktop or the BO server where the ODBC DSN is already defined.
herb3880 (BOB member since 2009-04-17)
