'Connection' SI_KIND in Query Builder
I have been querying the CI_SYSTEMOBJECTS table in Query Builder, and have for noticed that for some users they have several entreis where the SI_KIND value is ‘connection’. Some of these connections are several weeks old, and I know the user has logged out of the system since then. Usually when a user is in the system they have a connection instance in the query, which disapears after they log off.
Is there anyway I can determine what is causing these connections?
Thanks!
BOBJNewbie (BOB member since 2011-04-22)
