I am facing a problem that I can´t connect to CMC repository with the CMC credentials. IDT can´t reach to CMC server.
PS: I was working in another server and it was ok, but in the new one, I can´t connect.
1 - I opened all ports in linux and Amazon security;
2 - I disable all firewall in my machine;
3 - I can open a CMC and Launchpad;
4 - I did a telnet and it is ok (Amazon does not allow ping).
Did you resolve this issue as I have exactly the same problem wit BO full client trying to connect to BO box on AWS. No problem with firewalls and via BILaunchpad. All ports correctly assigned…
Any more ideas here??? I also have the same effect/issue with BO XI 3.1. SP6 on Windows Server.
We moved the Servers (both application Server and database), I stopped everything (all Services) during Transition. on the new machine I created a new SIA (because Location of database Oracle 11.2.0.4 has changed) but have no Connection between application and BO. (Application is a JAVA 1.7 one with it’s own tomcat).
I have Trouble with the ports… 6400 is in “waiting-state”, 6410 seems not to be open. Do I really Need both ports open???
And is it only a Problem of SIA and ports or may there also be another Problem with the SIA in my case??? (wrongly created?)
Can someone help me?
