connection error :DBD: No suitable driver found for jdbc
Hello Friends,
I am working on upgrade project where I need to upgrade BO XIR2 to BO XIR4 system.
We have BO XIR4 on win 2008 server and it has oracle 11g 64 bit.
Now I am trying to create connection with our existing database which is oracle 10g 32 bit.
I am getting follwoing error.
Thanks in Advance.
Manoj.s
manoj.s :india: (BOB member since 2012-08-07)
You need 32 bit driver to be installed on the server as well.
What are you planning to use ODBC, OLEDB or JDBC ?
Hello BO_Chief
Thanks for the reply.
The problem is solved it is JDBC driver issue.
And we need to copy that driver at below location with creating oracle as folder name.
C:\Program Files (x86)\SAP BusinessObjects\SAP BusinessObjects Enterprise XI 4.0\dataAccess\connectionServer\jdbc\drivers
in this path create a folder as name oracle and copy the ojdbc14 driver into this problem is solved.
But now I am facing new problem
I have configure everything my previous reports also get opened from BI launchpad but it works only with localhost, if I put server ip address or server name instead of localhost then I am not able to logon into this launchpad, due to this I can not able to access this from other system.
The same problem is with CMC also.
If you have any idea please suggest me.
Manoj.s
Does this server has configured with DNS ? You might need to knock the door of your Network team.
Check the HOSTS file as well.
Thanks for Reply
I made IP enrty into HOSTS file, but same problem.
I will talk with network team about DNS configuration.
Manoj.s
