Connecting Designer to SQL Server 2012
I have BO XI R3.1. I want to connect to SQL Server 2012 from Universe. Can anyone pls. guide me how can i connect it. BO Server & SQL Server are on separate machine. I was thinking of creating System DSN - ( ODBC or OLEDB) Connection on my client machine first and then use that connection in Universe.
Not sure if its right approach. Also, do i need to install SQL Client on client machine where i am using designer. Do i need to make change any option in CMC.
Diablog (BOB member since 2009-08-04)
You’ll need a DSN on the pc where you have installed Designer. If you want to query via webi, you’ll need the same DSN on the webi server too. When you’ve got a working DSN, you can pick it up with a new universe connection. Not sure that R3 actually supports SQL Sever 2012 though.
You don’t need an SQL client - but it’ll help to debug queries.
Debbie
With 2008, you could create an OLEDB connection and didn’t need any DSNs anywhere.
As Debbie says, I’m not sure if BOXI3.1 supports SQL Server 2012 - it doesn’t as of SP5, I’ve just checked.
I have never yet succeeded in getting an OLEDB connection to work consistently. No idea why. I gave up and went back to DSNs as they seem to be far more reliable. :wink:
Debbie
Interesting.
Never had a problem with them over 2005 or 2008. Can’t remember about 2000, it was that long ago!
Interesting thing is Microsoft intend to “do away” with OLEDB connectivity and make connectivity to SQL Server, in future releases, ODBC only.
Super!
:cuss:
