system
June 17, 2014, 3:14pm
1
Hi guys,
I have a requirement that I need to connect to SAP ECC from IBM’s DB2 to get infotypes data into the DB2 database.So could you tell me how can I connect DB 2 to SAP ECC using JDBC?
Niranjan
niranjan479 (BOB member since 2014-01-08)
system
June 17, 2014, 3:51pm
2
Hi, I do not fully understand your question. You want to connect via BODS to SAP ECC and you want to load infotypes in to DB2?
BODS handles this in 2 steps:
Connectivity with SAP
Connectivity with DB2
Both are covered in the manual and the wiki:
http://wiki.scn.sap.com/wiki/display/EIM/Connecting+to+SAP
Johannes Vink (BOB member since 2012-03-20)
system
June 17, 2014, 4:13pm
3
No,I don’t want BODS to do that.I need a connection b/w SAP ECC and DB2 to read the tables.
system
June 17, 2014, 4:18pm
4
I think we are talking different things here. Are you tallking about a SAP ECC system running on a DB2 database?
If so, you can ignore the DB2 part. BODS accesses SAP via the application layer and does not reach the database layer.
system
June 17, 2014, 5:00pm
5
No, I am not tallking about a SAP ECC system running on a DB2 database.
