BusinessObjects Board
Configure Xcelsius chart link to another Xcelsius Charts ?
Hi All Xcelsius Experts !
Is there a way to link (or Drill Down) from bar charts or column charts that will open up a windows to another XLF ?
For e.g. X-axis consist A, B, C, each correspond to Y-axis values, I will like to have a linkage if user click on bar A, bar B and bar C that will lead to another Xcelsius visualisation
Thank you !
seowkian (BOB member since 2010-10-26)
Yes. Flash variables is the way I do it. I have 4 dashboards for different work areas - a user can open any one and link to any of the other 3 via radio buttons which pass flash variables.
There are detailed posts in this forum that explain exactly how it works.
Debbie
Hi Debbie,
Are you able to refer me to the forum link on how to do it ? Thank you :slight_smile:
Christopher
http://scn.sap.com/message/13410398
http://megibi.com/passing-parameters-from-the-parent-dashboard-swf-to-child-dashboard-swf/
http://myxcelsius.com/2010/10/26/passing-data-from-a-parent-to-child-swf-flash-variables/
rizwan syed :us: (BOB member since 2010-07-08)
Search for “flash child” in this forum - too many to list!
Debbie
Hi Debbie and Rizwan Syed
Thank you very much ! Have a nice day : :smiley: :smiley: :smiley:
