Configuration tools
hi all…
i need some help…
Everytime i try to start configuration tool i get the following error:
java.lang.nullpointerexception
and my servers does not start…
any ideas ??
thanks in advance
Obara
Obara (BOB member since 2004-07-13)
Obara,
Welcome to BOB. :mrgreen:
Are you trying to launch the config tool on your server? Is Webi running?
hi MichaelWelter
Yes… i’m trying to launh configuration tools on my server… and WEBI is not running…
The BO server icon next to the clock just blinks…
It’s not starting up…
i’m running windows 2000 advanced server SP4 and BO 6.1b.
Well, that could be a clue to the problem. The configuration tool will not start while Webi is running, or starting.
Any idea why Webi isn’t starting? Do you have a valid .key file? What is your repository database? What version of Webi are you on?
