Configuration Tool - Java Problem
Hello,
i still have a Problem.
Win10 - 64bit and BO 6.54
If i start the Configuration Tool, i get a Error Message: “jre\bin\javew” not found. I installed it under: C:\Bo
The configtool.bat Looks like:
setlocal
set JAVA=start jre\bin\javaw
set CONFIGTOOLCLASS=ConfigToolUI
rem set CONFIGTOOLCP=../classes/configToolUI.jar
set _PARAMS=
:getParams
if ""%1 == "" goto :doRun
set _PARAMS=%_PARAMS% %1
if ""%1 == ""-cmdline set JAVA=jre\bin\java
if ""%1 == ""-cmdline set CONFIGTOOLCLASS=ConfigToolInLine
if ""%1 == ""-cmdline set CONFIGTOOLCP=../classes/configToolInLine.jar
if ""%1 == ""-help set JAVA=jre\bin\java
shift
goto :getParams
:doRun
cd ..
set PATH=%CD%\jre\bin\hotspot;%PATH%
set BO_TRACE_CONFIGDIR=.
set BO_TRACE_LOGDIR=..\logs
%JAVA% -classpath "%CONFIGTOOLCP%;../classes/configToolCustomer.jar;../classes/configToolCommon.jar;../classes/configToolUI.jar;../classes/asf_java.jar;../classes/bo_orb.jar;../classes/ldapjdk.jar;../classes/ebi.jar;../classes/wiutils.jar;../classes/asgui.jar;../classes/crimson.jar;../classes/jaxp.jar;../classes" -DTP_ONE=%TP_ONE% -DASF_PI_ENABLED=%ASF_PI_ENABLED% com.bo.configtool.gui.%CONFIGTOOLCLASS% %_PARAMS%
set CTERRORLEVEL=%ERRORLEVEL%
cd scripts
set ERRORLEVEL=%CTERRORLEVEL%
Before the reinstall, it was working fine… But i can’t remember, what i did Long time before.
Maybe someone can help me?
I know, it is a old Tool - but it works perfect. I want to change some in the key file…
BR
Steffen
Steffen11 (BOB member since 2011-02-16)
These lines:
%JAVA% -classpath
look suspicious. The path will not be recognized since the command line includes a directory reference. You may just need to change the first line to:
set JAVA=start javaw
but this assumes that the jre directory is underneath the current working directory. If not, you can hard-code the path:
set JAVA=start c:\bo\jre\binjavaw
Hello,
thank you for u Feedback.
I changed it and now Comes this message:
You have any idea?
BR
Steffen[/code]
Probably because this line is commented out:
Hello,
no, it wasn’t the solution.
Maybe it comes because of Java?
I couldn’t found the Problem… :expressionless:
BR
Steffen
The error means that Java is not able to find the “ConfigToolUI” class in the classpath. This means that there is no jar containing ConfigToolUI.class, or (more likely) the classpath doesn’t include the jar.
Ok…
Is it a Problem with the Jave JRE or do i have reinstall BO?
I have no environment variables for Java.
Maybe is it the reason?
It’s finding java.exe (that’s what’s generating the error). It’s not finding the right jars. They should be in a “classes” folder under the CWD.
Did you change the file structure, or the CWD?
Good morning,
the files are under: C:\BO\classes
I did not Change anything…
Thank you for your Patience.
BR
Steffen
Which directory is configtool.bat in?
C:\BO\bin\scripts\configtool.bat
Ok, that’s good. Is there any more text after the “Program will exit” message?
No, only this: Java Virtual Machine Launcher
I think it comes from Java - there are many postings on Google.
But i don’t know how to fix it :-(.
That message can have multiple causes, but generally the stack trace will be displayed which will give more info.
One possible cause is a mismatch between the JRE being used and the package. Back to your original problem – the installer should have installed the JRE, but apparently something went screwy with that since the first problem you had was a missing JRE. What happened to it?
Hello,
now it works, i copied all Java file in classes and all file from classe zu Java.
But now i get the Message:
You must have administrator's rights (or the equivalent) to launch the Configuration Tool. To configure the Business Objects server as a service, the following rights must be assigned to the user who launches the Configuration Tool and to the account used to start the service: "Act as part of the operating system" and "Log on as a service"
 To add these rights, go to the Windows Control Panel > Administrative Tools > Local Security Policy
I found these Option and i added my user name - but the message doesn’t move :-(.
BR and nice weekend
Steffen
Try running as a local admin.
