Conditional values
Hello,
I have an object that references a numerical column from a table. I wan it to rereturn the values in this way:
  • “Contains” if value=1
  • “No contains” if value=2
  • the original value if value distinct of 1 and 2.
Can I define it in the Designer? I have tried it defining the object format but the condoitional format only works with negative,positive or null value.
I’m working with Business Objects 4.1.1.
Thanks to all.
Are you using Oracle? If so, this is a simple DECODE:
DECODE( Value, 1, ‘Contains’, 2, ‘No Contains’, to_char(Value) )
Erich Hurst
Compaq Computer Corporation
(281) 514-9445
Erich.Hurst@Compaq.com
If-ElseIf-Else logic can be accomplished in the Formula Editor as follows (for your case):
=If <> 1 Then (If <> 2 Then FormatNumber(, “#”) Else “No contains”) Else “Contains”
This example assumes the column is of type character.
HTH,
Donald May
If I understand correctly, you could most easily do this with a decode in Oracle (assuming you are using oracle) in the object. Just:
decode(table.field,‘1’,‘Contains’,‘2’,‘No Contains’,table.field)
…you could also do this in a variable in BO:
if table.field = 1 then “Contains” else if table.field = '2 then “No Contains” else table.field
Good luck.
