Conditional Prompting
I have a request from a user to build a WEBI report where in the prompts they want to be able to select a partuclar promt value, and then based on that promt choose from a specified date.
Example:
User runs report,
first prompt on report asks for report type, so if report type “A” then the second prompt should be Start “A”.Date between End “A”.Date
First prompt on report is report type “B” then
next prompt should be Start"B".Date between and End"B".date
I would like to be able to choose a report type and based on the report type dynamicly chage the datefield range. Is this possible?
kcfox (BOB member since 2007-07-31)
Good Day,
Maybe THIS thread can help.
-John Vincent
jvmauricio :philippines: (BOB member since 2009-08-03)
