conditional prompt with dynamic operator <=> between
As per requirement I have to create a conditinola prompt for Start date where user can enter value for Start Date < = > and Between.
For example, If user wants to see all data for start date which is greater than ‘27-May-2007’ or start date = ‘27-May-2007’ or start date <‘27-May-2007’ or start date between ‘25-May-2007’ and ‘27-May-2007’ using prompt.
Please suggest how to achieve this.
Thanks in advance.
Spriha
Spriha (BOB member since 2008-05-28)
All those prompt conditions (equal to, less than, greater than) can only be given in separate queries.
You can however give a range of date prompts by saying date_obj between ‘From Dt’ and ‘To Dt’
Haider,
Thanks for quick reply but at a time user want only one condition to be executed like start date > Input date.
If I used different queries then all conditions will be executed which I donot want.
Is it possible to display result of only one data provider out of multiple data providers?
Please tell clearly what is your requirement.
How you want to define prompts in a query
Hi Haider,
Report will be running on following prompts -
1.Country
2.Code
3.Start date
Now requirement is User can enter start date for different conditions -
1.<
2.=
3.>
4.Between
For example,
If user want all start date<‘27-May-2008’ then report will be executed for
country = ‘United States’
code = 'US"
start date<‘27-may-2008’
or
user want all start date = ‘27-May-2008’ then report will be executed for
code = 'US"
start date = ‘27-may-2008’
Basically start date prompt will be considered as report refresh time.
Here User has some flexibility to choose for which condition of start date he wants to referesh reports.
Hope this time I am clear with my requirement
Please advise …
Then you need to have two different queries and set the prompt as desired.
You cannot have them in one single query as one is less than prompt date and other equal to. You can get data for either of them in a query
Hi, please review this topic for some ideas:
Hi Spriha,
I still believe that the above 4 scenarios can be satisfied using the condition of this type:
start_date between @prompt1 and @prompt2
  1. You get the 1st case (start date <…) when @prompt1=January 1, 1900 (or some similar date in the past) and @prompt2 is the date users need
  2. You get the 2nd case (start date =…) when @prompt1=@prompt2= date users need
  3. You get the 3rd case (start date >…) when @prompt1= the date users need and @prompt2=December 31, 2100 (or some similar date in future)
  4. You get the 4th case (start date between …) when @prompt1= the start date of the period users need and @prompt2=the end date of the period users need
It all will work when you train your users and explain them what to enter for @prompt1 and @prompt2 in which scenario.
Hi Dave,
This code works absolutely fine for ‘<’,’=’ and ‘>’. But when I add ‘between’ as well with two prompt text then 3 prompt window opens
1.For enter operator.
2.To Date
3.From date
Now if user wants to select Effective date = prompt date then Ok button is not enabled.(As second prompt text is not selected)
Please advise how to fix this issue.I mean to say if User select ‘<’ then he can get only single prompt if user select between then he will have 2 prompt
Spriha
Prompts are all independent. It is not possible to have the values of one prompt based on the result of another prompt unless you use cascading prompts.
What I mean is, if the user selects “between” or something else, there is no way to enable / disable the next set of prompts.
Hi Dave,
Can you please suggects how to achieve using cascading prompts? I created a cascade object and edited its LOV with case statement
case when obj=’<’ then date <@prompt()
when obj=’>’ then date>@prompt()
when obj = ‘between’ then date between@prompt() and @prompt()
When I try to refresh object its display 3 prompt window (same what I was getting last time).
I don’t believe cascading prompts are a solution to this issue. They are designed to be a sequence of prompts, but they are not going to allow you to suppress a prompt if a value is selected.
