The problem is the conditional highlighting in a crosstab. There is a simple crosstab with one the column year and the rows displaying commodity natural gas and oil
The table’s got two measures, a value and a limit value. Now I want to create a simple conditional formatting. If the value higher than the limit, make it red, else green.
if {Report.Value} > {Report.Limit}
then red
else
green
The problem is, it always turns red, even if the limit is higher than the value. The formula works in a normal table in the detail section. Obviously the condition compares the sum values of the row for limit and value. I tried the currentfieldvalue function, but this does not help for my comparison.
Somehow it must be possible, in Webi it is very easy to do this.
I am not so experienced with Crystal, more spoiled with Webi.
thanks in advance
Hell AhirBO,
I tried this. However the formula editor in the condition button alert function only allows text strings. Maybe I don not understand your solution:
However t’'ve asked the question in the sap forum and I’ve got an answer which is feasible (with one defective appearance)
f CurrentFieldValue>GridValueAt (CurrentRowindex,CurrentColumnIndex ,CurrentSummaryIndex+1) then crgreen else crred;
The only problem is, I have to place the second field (the value to compare with) as well in the crosstab section. It is suppressed, but it needs some space, even with minimum height.
