I need to format a field based on the row title.
Is there a way to format the field with a $ or % or no symbol, based on the row title? The example below consists of two fields. The title field and the amount field. The amount field would have conditional formating based on the title field.
I know I can do colors but can I do symbols with conditional formating?
Example:
IF row title is “Employee Contrib $” THEN append “$” to the amount field ELSE
IF row title is “Employee Contrib%” THEN append “%” to the amount field ELSE
IF row title is <>[Employee Contrib%, Employee Contrib $] THEN append “” to the amount field:
Row Title --------------JMFG-----------AEM------------PCI
Employee Contrib $----$50.00----$10.00---------$60.00
Employee Contrib% ----%10--------%.5---------- %30
kmonoh (BOB member since 2008-08-15)
