I have a requirement to extract data from the same DSO across different countries to different target tables. This extract will be via Open Hub, I am planning to set up a seperate Open Hub table for each country with each Open Hub DTP containing a country filter.
These DTP’s will however run in parallel and I am not sure if this will cause problems. Can anyone confirm that this approach will work as described?
mthom (BOB member since 2009-09-14)
