Cannot find NT Oracle Server DLL <OCI.DLL>. Please make sure that Oracle has been installed and the PATH variable points to the correct lib directories.
I have seen this link
Able to connect using SQLplus…
Able to create and import table using Data Services Datastores for Oracle 10g
Checked Already:-
Checked path @ control panel → system → Advanced → Environment Variables → PATH forOracle\bin directory, Orale_Home, OCI.dll
where are you getting this error ? when executing a job ?
the link that you have provided points to a discussion on LOV in Universe Designer, it has nothing to do with DS Designer or DataServices
if you are able to create Datastore and import tables, then there should be no problem executing the jobs on the same machine
check under what user DataServices Service is running ? try changing to same user as you are currently logged in are able to work in Datastore in Designer
Yes we have successfully configured Datastore for Oracle 10g and imported tables as well.
How ever when we go for execution it shows the error.
We are running under the Super User which we have used to install Data Services and Oracle Client.
Reference:–
Some versions of Oracle Clients are affected by Oracle Bug 3807408.
These versions are: 9.2.0.5, 9.2.0.7, 10.1.0.5, 10.2.0.2
The issue is fixed in the following versions: 9.2.0.8 (Server Patch Set), 10.2.0.3 (Server Patch Set), 11.1.0.6 (Base Release).
