#COMPUTATION error...please help!
OK, I have a query that pulls in a field (pay period) which is alphanumeric. In my report, I need to divide by a substring of this field. So, what I need to do is take a substring of pay period, and then perform a ToNumber function on it so that I can use it in a calculation.
To do this, I create a variable that substrings it, then create a second one that changes that new variable to a number. I then try to use that variable in a calculation and I receive the #COMPUTATION error. I’ve used similar logic in other reports and it’s worked fine. Any ideas on what I may be doing wrong? Thank you in advance, this is KILLING me!
ryanferrario (BOB member since 2004-02-27)
What the formula causing a computation error? Which variables are displayed in the same block as the “problem” formula ?
I have figured it out. Thank you to all who took time to respond (Andreas) or were thinking about it.
Well, care to share what you did to solve your problem, please? :mrgreen:
Hi Andreas,
=Sum() Where (=2004) it’s working fine when i take user responce insted of 2004 it’s giving syntax error
=Sum() Where (=ToNumber(SubStr(UserResponse (“Query 1” , “Enter Year & month YYYY/MM”) ,1 ,4))) --this is throwing an error
Thanks in advance,
Matt
matt_man2004 (BOB member since 2004-06-12)
Take a look at our FAQ: Reporter and you’ll find this entry.
I’m surprised that the “>=” even works – perhaps you’re on a newer version? Traditionally, the SUM (WHERE…) required that the operator needed to be an equal sign.
And, the operand to the right required a constant or a variable – no functions. So try creating a new variable called whatever you want, I"ll pick “X”:
X =ToNumber(SubStr(UserResponse (“Query 1” , “Enter Year & month YYYY/MM”) ,1 ,4))
and then change your SUM() Where (= X)
Hi Anita, if you see there’s no “>=”, it’s <J Fiscal Year Id>=2004 :wink:
Mario.
mhma1979 :peru: (BOB member since 2005-01-24)
Whew! Just my blurred vision kicking in! :rotf:
Hi Anitha,
I created exactly what u said here but it still giving syntax error
X =ToNumber(SubStr(UserResponse (“Query 1” , “Enter Year & month YYYY/MM”) ,1 ,4)) from this variable i am getting 2004,if i hardcode in place of X it’s working fine but if i use variable insted of X giving error.
=SUM(MTD Shipped Cases) Where (J Fiscal Year Id= X)
please help me out guys…
Matt
Hi matt!
is number or string?
Mario.
Hi Mario,
data type is Number
Matt
Why don’t you create a formula like this:
If J Fiscal Year Id= X Then MTD Shipped Cases
And then sum that new variable in your column… did it work?
Thanks Mario.
Actually this is a cross tab report if i use =If J Fiscal Year Id=X Then MTD Net Dollars giving me #computation error
if i included J Fiscal Year Id in cross tab then it’s giving multival error
Matt
Sorry, but I don’t get if that helped you or not :?
:lol:
i am still getting same error’s ,please help me…
Matt
have you tried:
=If J Fiscal Year Id= X Then MTD Shipped Cases Else 0
and then sum this new variable?
Sorry, my error – since “X” is a variable, you have to enclose it in the same angled-brackets as other variables:
=SUM() Where ( = )
