Complex prompt : mixing like and in sql operators
Hello All BOB ! :wink:
In some reports we are currently developping, we face a crasy problem :
In prompts, our client want to make a IN selection using List of Values, and, after, the selection would be a “like” of each element selectionned.
For example, user selects in LOV values [titi, toto, tutu], to choose titi%, toto% and tutu%
How can this be done ?? :confused: :confused: :confused:
thanks for advance
Bernard
and, after, the selection would be a “like” of each element selected.
toto% and tutu%
HYPOTHESIS:
The elements of the LOV have the same length.
If so, and if you have the following where condition:
TABLE_WORK.WORKER_NAME IN @Prompt(‘Who is?’, {‘titi’, ‘toto’, ‘tutu’})
… you can rewrite it as follows:
substr(TABLE_WORK.WORKER_NAME, 1, 4) IN @Prompt(‘Who is?’, {‘titi’, ‘toto’, ‘tutu’})
NOTE:
If the TABLE_WORK.WORKER_NAME is INDEXED, with substr you’ll lose any benefit of the index!!
If the elements of the LOV aren’t of the same length… let us know! :wink:
Donald Duck :mexico: (BOB member since 2004-07-29)
Value LIKE CONCAT(@prompt(‘Select from LOV’,‘A’,mono,constrained),’%’)
Above example is for Oracle. Your wish to combine LIKE and IN is, in my opinion, impossible. If not, I would not know how to!
jobjoris :netherlands: (BOB member since 2004-06-30)
The concatenation of the prompt with ‘%’ is a good idea! :wink:
