Complex Formula for Header Date and Year
I am trying to implement a formula , but somewhere I am doin wrong.
="Incremental Numbers Of The Branches Between 1 and 275 For the Month of "+Month(Max(ToDate([MIS Account Open Month ID];"MMM"))+" "+FormatNumber(Year(Max(ToDate([MIS Account Open Month];"YYYY")));"####")
The value in MIS Account Open Month ID is like (200804,200706) and it should be read as April 2008 or June 2006.
Please someone give some suggestion or solution to this problem.
Thanks Aniket
This may not be that neat.
But why don’t you convert it to a string and trim the last two digits and then with an If Else If logic, bring out the month name in the place of month number?
Can you please give me a sample code help , as I am stuck with this problem and not getting how to solve this issue?
Liv the max logic , simply if i want to display month and year what can be done?
Please suggest some code. Thanks for your help
Aniket
Or try this
=FormatDate(ToDate(FormatNumber([date_num] ,"000000") ,"yyyymm") ,"Mmmm yyyy")
How crooked my idea is! :oops:
Follow what Haider told, as it is just a one step process
Haider Can you please explain me whayt is the significance of using “000000”
Aniket
ToDate function accepts only string. So FormatNumber function is used to convert a number into a string in the needed format. As far as I know =FormatNumber(200804 ,"") will result in 200,804 including thousands operator ‘,’ in the number. To get rid of that and =FormatNumber(200804 ,"####.00") will result in 200804.00 giving two decimal places to the number. So it is up to us to choose either # or 0 without ‘.’ to get the desired format.
Haider, please let me know if I am wrong.
Instead of using “,” I have to use “;”:
="Incremental Numbers Of The Branches Between 1 and 275 For the Month of "+FormatDate(ToDate(FormatNumber([MIS Account Open Month ID] ;"000000") ;"yyyymm") ;"Mmmm yyyy")
It is not displaying anything , i think there is some mistake in the code i am using,
AniKet
I agree as you are in Web-I
But the code you mentioned is right. To test what causes the problem, split the formula into many parts and check it incrementally.
Thanks a lot , now its working.
If i want to use Max with this , can it be implemented . I tried using
="Incremental Numbers Of The Branches Between 1 and 275 For the Month of "+Max(FormatDate(ToDate(FormatNumber([MIS Account Open Month ID] ;"000000") ;"yyyymm") ;"Mmmm yyyy"))
Is the above query right ?
Jansi can you please let me know ?
Aniket
It depends on what your dimension [MIS Account Open Month ID] has in it.
It has values like :
200804,
200803
200704
In this manner the data is there in this object./
Aniket
Ok fine… What do you want in the header actually(as per your requirement)? Is that the maximum value you need? If yes, then go ahead :slight_smile:
Thanks a lot Jansi.
Aniket
This is the original problem :
but today i encountered the same problem , sorry for posting the issue again.
I have a field whose type is Number and the values present are 200808,200804,200607,
Now i want to display : Month = Aug 2008 , as the max value present is 200808. So how it can be implemented please help.
Thanks Aniket
Till some extent i found the solution.
Steps:
The values for Month is in number : 200801,200802, 200808
Now first i calculated the max , Max([Month Id]) it gave me = 200,808
Then as per the prvious query i used :
FormatNumber(Max([Month Id]);“000000”) it gave me = 200808
Now after that i tried using , ToDate function , but its giving January’s data. and its displaying Januray 2008 but i want to display August 2008I don’t know why it’s happening , and i am struggling with this problem from a long time , please if someone can through some light on this …!!1
Thanks & Regards
Aniket
Post your exact formula and try using FormatDate. Previously you got the solution after trying what was suggested in that link right? Also you could have continued there itself instead of opening a new topic for the same problem :slight_smile:
Ya i know i could have continued that , but i thought if i continue then the 3 days back post will open again , and thats the reason i dint post there.
And the exact formula I am using is :
The below forula gives me : 200808
="Banding Numbers For The Month of "+FormatNumber(Max([Financial Month ID]);“000000”)
Finally i want to display August 2008 , but when i am using todate() function , it is showing 1/1/70 , i think its not taking todate() function ,
so now i got stuck , as the final output with the final formula is
="Banding Numbers For The Month of "+FormatNumber(Max([Financial Month ID]);“000000”) = 200808
And i need it to be August 2008. But nothing seems to work here.
Aniket
What are you getting if you use this?
=Max(FormatDate(ToDate(FormatNumber([Financial Month ID] ;"000000") ;"yyyymm") ;"Mmmm yyyy"))
Its Displaying January 2008.
Till FormatNumber() it’s working fine , but after encountering ToDate() function its not working. That’s why in the end It’s giving January 2008.
Can u plz suggest if any any other alternative is possible or not ?
Thanks a Lot
Aniket
