BusinessObjects Board
Combobox does not populate data to destination with QAAWS
I have 3 combo boxes to filter data. The destination of each combobox is within the sheet.
When i hard code the data into the excel sheet the comboboxes work fine.
When i replaced the data with a QAAWS connection, the comboboxes does not populate data to the destination anymore.
Please help!
MonishaMukesh (BOB member since 2015-07-23)
Some standard troubleshooting questions:
Are you certain the QaaWS is refreshing?
Are you certain the QaaWS is writing to the correct cells?
(These are best checked by adding a temporary Spreadsheet component to display the content of those cells.)
Are the combo boxes still reading from the correct cells?
Is there any formatting issue with the data they are reading (e.g., trailing spaces)?
