Good day Experts!
I normally just lurk as there is such great information here. However, I could not find this issue among the many solved issues on within this forum.
I have two independent combo boxes: Region and Country. Both default as “None selected”.
You choose a Region and QaaWS is triggered to pull the countries for that region and the post combo box becomes visible.
A “GO” push button also becomes visible once a Region is selected as well. The “Go” Push button is setup to trigger 10-12 QaaWS calls which load all information pertaining to Region and country if the country is selected.
I have a Reset button that is supposed to reset everything back to re-choosing the Region and country if the user so desires.
Here in lies the problem:
What currently happens is once the “Go” push button, combo boxes are no longer clickable, they are visible but I cannot interact with them. Push buttons become unable to interact with as well.
I have tried working with “Bring to Front” and some other settings. I was wondering if anyone has had this issue before. It has me stumped!
The only thing I can think of is that the “disable mouse interaction” on connections loading is bugging out my components. Is this it?
Thank you for any help you can provide,
Xceletron!
Xceletron (BOB member since 2010-09-09)
