I have a requirement creating dashboard from two different queries. I have used 2 combo box which I have data flowing from bex query eg Company and Customer. In Combo box— Behavior----Insert Selected Item—Label.
When I Preview the Dashboard it is totally blank and the user have to click manually the combo box to interact. Is it there any possibility to view the dashboard when previewing i.e the Combo box should contain default value automatically.
The Reason behind I kept label is the two queries have Different customers and the 4 charts are mis-matching if i keep it as a position. Only Label option is working fine except the automatic the default value. If any one can give solution my requirement will be over.
Pradeep
padykr (BOB member since 2015-12-23)
