I have 8 DB and 8 universes pointing to each DB, and i need to create a global report which will contain data from all the 8 sources…I can only think of these options
create report using 8 data providers -> but user needs adhoc reporting and creating so many data providers is not possible for the user
Create materialised views at the DB and then develop a ‘Global’ universe that will contain data from all sources -> from here user can pull the desired objects but i believe it will create performance issues.
Is there anything else, any solution to this problem…user doesnot want standard reports…Your help is much appreciated
Mark, business has not maintained its stuff properly. I adviced for datamart too but some clients are adamant : ) , so i was trying to find some other way out.
