BusinessObjects Board
Combination of Stacked Column chart with Line Chart
I am new to Crystal Xcelsius.
We have a requirement of graph which contains a combination of Stacked column chart with multiple lines in it.
I have checked all the available charts but not found this. Please let me know if anyone has came across the similar issue.
Sriram
bouser1 (BOB member since 2008-08-01)
You’ll need to layer your charting. This involves creating the stacked bar chart, then putting a line chart directly over top of it (make sure you turn the background off). This process involves a lot of pixel pushing and axis futzing to get right and remain scalable, but is completely possible.
I would argue, however, that the choice to use a visualization like that may not be the most effective way to depict the data. Hard to say.
andyafco (BOB member since 2009-01-31)
Thanks Andyafco for your input and have implemented it working fine.
We have a requirement of 2 dimensions and 3 measures to place in a graph so for that reason why we want a Stacked column chart with 3 lines over it.
Thanks & Regards
Sriram
Anyone knows if a Stacked Bar + multiple lines is available at the last version in Dashboard Design ot whatever they call it now? :wink:
Posted: 17/7/2014
TurningPointHolland :netherlands: (BOB member since 2006-09-06)
It does not appear to be. We are just starting testing on the latest version.
