COM Provider CLSID Not Specified or erroneous
Hi Gurus,
We are using BO XI R3.1 version. We have 3 environments to say… DEV, TEST and PROD.
when i develop a new report using webintelligent and run it im facing a problem in TEST environment but, when i develop and run the same report ( using same universe and same objects) in DEV environment I’m able to run it successfully.
Here is full description of the error/problem I’m facing.
‘A database error occured. The database error text is :(CS)
“COM Provider CLSID Not Specified or erroneous”. (WIS 10901)’
kindly suggest me the solution.
modu (BOB member since 2010-09-01)
I did get the same error wnated to check if you did get a solution for the problem? Please let me know if you found an answer. I would like to know.
thank you
kind regards,
K
kumaraxl (BOB member since 2012-08-28)
hi,
I think i found a solution, Please follow the link.
http://scn.sap.com/thread/1294539
thank you.
K
