Columns to Sections
Hi All!
In the database has a table with the structure:
table_name (device_name, Param1, Param2, Param3)
device_name is dimension
Param* is measure
I need display Param* in the form of sections in report WebI
Now I do it with “union all”
select device_name, Section1, Param1
union all
select device_name, Section2, Param2
union all
select device_name, Section3, Param3
Section* is dimension
Param* is measure
and, Section* is sections in report
How can this be done without “union all”?
Thanks!
obnin (BOB member since 2010-07-08)
Hi obnin,
How are you doing it with Section1,2 and 3,please explain.
swap_l (BOB member since 2009-04-09)
hi swap_l,
In Universe made three dimensions: Section1,2 and 3.
And fill it ‘Section1’, ‘Section2’, ‘Section3’.
Then I create a query for report in such a way as in my first post.
