Can someone let me know, if there is a way to sort column names in a table that we insert into a universe. When we insert a new table into the universe, the columns in the table gets displayed as it is defined. Can we order that in alphabetical order?
Thanks!
Mugil.
haimugil (BOB member since 2006-05-17)
First, welcome to B:bob:B!
Second, I’m going to move this topic from the BusObj Classic forum to the Semantic Layer forum where Designer is discussed.
Third, the answer is yes, but you need to let us know which version of Designer you are using, because the solution varies.
Dwayne Hoffpauir
(BOB member since 2002-09-19)
Thanks for you response. I am using version 5.1.8 and trying to pull in tables from oracle or db2
Thanks!
Mugil.
Take a look at this thread.
Dwayne Hoffpauir
