Collapse Input Control on open
Hello all-
I am unable to locate any information related to having a document open with the input controls all collapsed, as opposed to having each display say 5 values each. I do not want to restrict the visible values to anything less than 5 when actually expanded, so setting them to 0 or 1 really isn’t an option.
I can collapse them all and save, but when opened again, they are all expanded to the view value setting.
Maybe I’m not explaining what I need well enough that no one has replied?
I’ll try to add some graphic to help.
Top one is what I currently have, the second is the desired look.
I’ve never seen an option to set them to collapsed on open.
there is likely a way to update a web application file and set the the default to collapse all. But, it would be a global setting, and not what report users with 1 or 2 input controls would prefer.
