I have a Cobol copybook that defines a field as PIC S9(8)V99.
For all “positive” numbers, I am receiving valid results.
For negative numbers ending in “0” (zero), I am getting valid results.
My issue is, for any value where the pennies column is 1 - 9 I get invalid results. My understanding of Zoned-Decimal is that the last byte will contain “A” through “I” for digits 1 - 9 positive and “J” through “R” for digits 1 - 9 negative. Positive zero = “{” and negative zero = “}”
I am receiving a value of ‘000000291Q’ which should resolve to -29.18, but instead it is resolving to -29.11. I have veriifed this back to the file, and I have used Designor Data Profiling to verify this.
Can someone please assist me in this?
I do not want to change the copybook to VARCHAR(10) and then write a transform to manage the type conversion to numeric based on a decode of the last byte, but I will if I have to. Argh!!!
Thanks …
Jeff in Chicago …
jwilgus (BOB member since 2008-01-17)
