Hello,
I’m working on BO XI R2 - Solaris and I try to set up the CMS database (using cmsdbsetup.sh) on Solaris with a Sybase DB server.
cmsdbsetup.sh ask for this information:
Please specify Source CMS database connection information.
Please enter the service name for connecting to your Sybase database.
Please enter the user name for connecting to your Sybase database.
Please enter the user password for connecting to your Sybase database.
After set up this, I get the following errors:
err: Error: Failed to initialize current data source.
err: Error description: Unable to connect to the database using the provided connection string. Reason: Database Access Failure.
CMS Data Source setup finished.
I check with my Sybase DBA and it seems some information are missed during cmsdbsetup.sh: database server name (or ip), port…
I already work on Oracle and the description of the server name (or ip), port… was defined in tnsnames.ora
My Sybase DBA says there is a similar file that sould be set up:
- at Sybase client level (interfaces file)
OR - at BusinessObjects level (odbc.ini or somewhere else)
Do you have any ideas, please ?
Do you know where cmsdbsetup.sh store given information during set up ?
NoNoDiabolo.
nonodiabolo (BOB member since 2006-09-12)
