CMS Query Properties
The listing of fields, etc. for querying the CMS database doesn’t seem to be working at:
http://www.sdn.sap.com/irj/boc/sdklibrary
The items are listed, but the additional info in the right hand pane won’t display.
Does anyone have this information from a different source?
dukeslater (BOB member since 2007-02-15)
Turns out it’s a security issue with the help file.
If you’re trying to access them from the web then it’s a Windows issue and there are workarounds on the web. If you’ve saved it locally, which I had done, you just right click on the file, select Properties, and you’ll see a button titled ‘Unblock’. That solved my problem.
