CMS not starting
i have installed BOXIR2 on my Laptop (XPSP2), i could not start the CMS at the end of the installation. i am using Mysql as sysdatabas & Audit.
i have gone through the forum.
tried to solve it by checking the event viewer.
the steps i checked are…
went to host file in Windows and added my server name to it.
i checked the event viewer again and it said that port 6400 is been used by other application.
then i changed the port number of CMS to 6401 and tried to start it. it appeard as started but when i started other services i had errors in event viewer as “Could not connect to CMS”…
i was bit dissapointed because i couldnt find proper solution after lot of search…
if any one has faced such problems & fixed it please send me step by step approch to solve it.
Thanks very much in advance…
Arvind
arvind.alex :uk: (BOB member since 2005-05-14)
Arvind,
Have you checked for clues by reading the error log for CMS under “c:\Program Files\Business Objects\BusinessObjectsEnterprise 11.5\Logging”?
You mention the use of MySQL. In some cases you must set up MySQL to perform under BOE properly. To double-check your MySQL .ini settings, please follow this post:
John
jsanzone :us: (BOB member since 2006-09-12)
Hi ,
I tried what you said but it didnt work. so i reinstalled BO and put the port number 6401. and it installed fine…
but now i am able to logon to CMC and when i logon to Infoview i get the following error:
Account Information Not Recognized: The initcofig.file doesn’t exist, please contact administrator.
does any one know how we can fix this.
thanks,
Arivnd
Arvind,
I just re-read your original posting:
Looking at the BOE XI R2 Supported Platforms (Windows) PDF, under Server Products, it lists only Windows 2000 and Windows 2003 Server types, not XP workstation. I have heard in the wild that others have been able to get XI R2 services to load on a XP workstation, but I don’t know exactly how they did it and what gymnastics they had to perform to get there. If at all possible, I’d suggest reformatting your laptop as a Windows 2003 Server and try again…
John
hi jsanzone
i know that if i install 2003 server on machine on mylaptop i can do it… but i also know that we can install it all working in XP professional SP2.
If any one had faced such problem please let me know how to solve it.
:hb: :+1:
Arvind
Try specifying ip and port no in configuration properties of all the services. In your case it would be IP:6401
BOB_Learner (BOB member since 2009-03-24)
