CMC logon not working BO Edge 3.1
Hello everybody,
after installation of BOBJ Edge BI 3.1 SP2 (Windows Server) for Server Components and SP2 for SAP Integration Kit the BO Central Management Console is not working. The logon is not possible. There comes the error message:
HTTP Status 404 - /PartnerPlatformService/service/app/logo
type Status report
message /PartnerPlatformService/service/app/logon.do
description The reguested resource
(/PartnerPlatformService/service/app/logon.do) is not available.
What shold I do to get access to CMC?
Thanks in advance for any help!
regards,
hugo
Hugo (BOB member since 2010-04-14)
Try to redeploy web applications.
vovasyd :ukraine: (BOB member since 2009-10-15)
Hi Hugo,
did you resolve your problem? If yes - what did you do?
We are experiencing the same trouble.
Best regards
aku
aku (BOB member since 2010-05-11)
