There are some issues with this datatypes @ Oracle and 3rd party products.
I tried to do an insert select statement with clob fields in both tables and they are running fine even with strings with 4000+ chars (at database).
So i think you can do something like this.
Try to cheat on DI datatypes importing the table with varchar(4000) in both source & destination. Do your query in a way that it gets pushed down as an insert select statement. Then change Oracle tables to CLOB without reimporting them and run your DF, as long as you don’t make function calls, filter, distinct or group by on CLOB fields in your statement, i think it should work.
