system
May 23, 2011, 12:00pm
#1
Hello experts,
I am new on BO development and I am not aware about what version matches with system.
I had to uninstall BO client from my workstation due to an old version, now I need to reinstall Edge and Integration Kit… how can I know exactly what client version I can use without problems?
flaviaandreoli (BOB member since 2010-11-18)
system
May 24, 2011, 11:04am
#2
Check the SAP web site. Amongst the documents, there are also so called PAR documents that list the supported platforms for a specified BO version.
Check also this sticky topic where it’s described how to find PAR documents on the SAP web site:
The sticky topic contains hints how to navigate on the SAP web page and where to find what is supposed to be there.
Please post in the following topic your other suggestions what should be in this sticky:
system
May 24, 2011, 11:07am
#3
Make sure you re-boot and clean any left over BO regsitry keys from your system. This may save you having problems later on…
Mak 1 (BOB member since 2005-01-06)
