deleted registry still facing the same problem.boxi r2 version
spazoo_141 (BOB member since 2010-05-27)
Any object?
Nick Daniels (BOB member since 2002-08-15)
yes if we click on any object.designer hangs
Try making a brand new universe, see if that causes the same behavior. Also if you have previously used a two-screen configuration (such as a laptop connected to a projector or other external monitor) then go back to that setup (add your second monitor) and make sure the properties window isnโt coming up off-screen. That is the most typical reason for this behavior in my experience.
Thanks for the reply.done with the new universe still facing the same problem.iam connecting to only one system not to projector
