Classes and objects Automation
I found a very useful tool :
https://bobj-board.org/t/82051
I tried from my side but I am not able to make tis tool work.;
Somewhere I think I am going Wrong.
Can anyone advise me on the same.
Aniket
Aniket, this is at least the fifth message you have posted that basically says the same thing. “I’ve tried this utility and it’s not working.” That is not much to go on. Please give us more details. What did you try? What version are you using? Is there a specific error message?
And as with your other topics :slight_smile: please post a Reply in the download topic, rather than starting a new topic. That way the author / owner of the code you’re trying to use will be more likely to see your question, thanks.
