class and objects in crystal report
Hi experts,
Could you please tell me how classes and objects are represented in crytal report when creating report from universe in cystal reprot 2008. Will classes and objects be like columns ? as in case of database tables?
alex1234 (BOB member since 2010-09-14)
When you are creating report with the universe follow the ff steps
connect to the universe
create a query with the objects in the classes of the universe
with the query u can now create your report in crystal report.
zeelod11 (BOB member since 2012-03-13)
Thank you for your response,
I could not understand properly. Could you please explain little more…
use the database expect to connect to the universe
a query panel will come up similar to qaaws quary panel (here you will see a list of class and objects)
use this to create a query, depending on your spec
then move the greated query to the selected table in the database expect
use this to create your report
